Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IMPORTANT: ALL MK3 Focus Owners, I could use your input.
Old 11-15-2012, 06:05 PM   #88
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
Points 299, Level 5
Points: 299, Level: 5 Points: 299, Level: 5 Points: 299, Level: 5
Level Up 98% Completed
FF Reputation: 3 sgmfocus Good Standing Member
Zillon had an idea or suggestion,i use to have an 04 dodge stratus they had a clunking noise on 01 thru 05 sedan model years. they issued a tsb here are the symptoms
SYMPTOM/CONDITION:
Vehicle produces an intermittent front end popping or clunk type sound while driving over road inputs that cause the body to come under a twisting load. This sound may also be produced when in park & idle by turning the steering wheel quickly, 90 degrees, to the left and back to the right
is this the clunk that everyone has? the clunk was coming from wheel well where it joined firewall fix was putting in two rivets .i have the whole tsb if you think it might help
sgmfocus is offline
