Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IMPORTANT: ALL MK3 Focus Owners, I could use your input.
Old 11-15-2012, 10:40 AM   #76
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
What I Drive: 2012 Ford Focus SE Sport - 5 Speed
Points 23,589, Level 94
Points: 23,589, Level: 94 Points: 23,589, Level: 94 Points: 23,589, Level: 94
Level Up 24% Completed
Forum Activity 45%
Activity: 45% Activity: 45% Activity: 45%
FF Reputation: 16 Shade-010 Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by Zillon View Post
That's the one thing I won't be installing, since they're prohibitively expensive at ~$13 per bolt. The Ford bolts are specialized, due to the unthreaded shank on the bolt and the hardened steel spacer, but they're only grade 10.9 fasteners.
I have sourced similar grade 10.9 M8 x 1.25 x 30mm flange bolts that I will be using instead, and I will also be torquing them to factory specs.
I will also be re-using the hardened factory bolt spacers, since I cut them off of the factory bolts and drilled them out to fit over the threads of these bolts.
But with the reinforced bar the spacers (washers) are thinner then the ones without
2012 Ford Focus SE Sport-5 speed-203A package
Basline 1 -155.48hp 145.80 tq 93 oct. Lunchbox delete & K-N Drop in filter.
Dyno 4 -177.17 hp 157.28 tq - 93 oct. RDC 2.5" Catback & RD-X Prototype CAI + Tune.
Shade-010 is online now
