Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IMPORTANT: ALL MK3 Focus Owners, I could use your input.
Old 11-15-2012, 11:33 AM   #75
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by stang74shelby View Post
What about the stock bolts needed for the reinforced bar?
That's the one thing I won't be installing, since they're prohibitively expensive at ~$13 per bolt. The Ford bolts are specialized, due to the unthreaded shank on the bolt and the hardened steel spacer, but they're only grade 10.9 fasteners.
I have sourced similar grade 10.9 M8 x 1.25 x 30mm flange bolts that I will be using instead, and I will also be torquing them to factory specs.
I will also be re-using the hardened factory bolt spacers, since I cut them off of the factory bolts and drilled them out to fit over the threads of these bolts.
Joined the dark side.
Zillon is offline
