Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Offset 10+
Thread: Offset 10+
Old 11-15-2012, 09:13 AM   #26
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
FF Reputation: 11 hEaT Great Standing Member
Please don't cut the struts. That is just plain dangerous. Do it right.
Also, SVT struts cannot be lowered 2". They are stiffer, but do NOT handle working outside of their effective range OR stiffer springs. Even cutting the rod to put the travel in their optimal range will still cause them to blow quickly due to how stiff of a spring you need to lower the car where you want it and not ride on the bump stops.
I'm all for saving money when you can, but never when it compromises safety. If you want low on a budget, go with Racelands. They are GARBAGE, but at least won't kill you.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster.
...idiots
hEaT is offline
