Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What should I do now?
Old 11-15-2012, 07:50 AM   #9
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 39,119, Level 100
Points: 39,119, Level: 100 Points: 39,119, Level: 100 Points: 39,119, Level: 100
FF Reputation: 35 tukaniSVT Great Standing Member
When doing your timing belt you adjust your tensioner to get the belt nice and tight or loose for take off.
Well, on the Zetecs, there is a little window with a marker for the optimal spot for your timing belt to be tensioned. As you tightened the belt you will see the marker go to the window. When you turn on your car this shakes a bit and moves some on acceleration, but in idle, it should stay pretty close to the marker in the window.
You will be surprised how that little detail can make a difference.
Did you crank the engine by hand a couple of times and re-checked the timing was still in time after hand cranks?
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
