Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus 2012 +12V Ignition Help!!!
Old 11-15-2012, 07:30 AM   #4
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
you are correct in that there is no acc wire in the harness. it's all data now to control everything. be careful with the wire you did use as it's not designed for added power like that. you could use a relay on it and get power from the constant wire. or a better option would be to run it to a wire in the fuse box or ignition switch.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
