Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - rear suspension removal -- in junkyard
Old 11-15-2012, 01:59 AM   #4
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
Points 909, Level 16
Points: 909, Level: 16 Points: 909, Level: 16 Points: 909, Level: 16
Level Up 9% Completed
Forum Activity 4%
FF Reputation: 1 finalfantasy Good Standing Member
Originally Posted by Tymes View Post
As for the springs, until you disconnect the control arm from the spring seat, it can't drop low enough to release the spring, regardless of the shock being there or not. But yes use a jack under the spring seat when you disconnect that bolt.
but you have to remove the shock too right or you cant get the coil out, right? they both limit, but the control arm more?
finalfantasy is offline
