Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Why would a Slave cylinder keep going bad?
Old 11-15-2012, 12:26 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
What I Drive: 01' Yellow ZX3 euro, 04' ZX5 SVT
Points 159,392, Level 100
Points: 159,392, Level: 100 Points: 159,392, Level: 100 Points: 159,392, Level: 100
FF Reputation: 51 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Welcome to the Forum
If 3 in a row are going bad then I would start looking at the other clutch parts such as the pressure plate and clutch. Also check out the Master Cylinder at the pedal for leaks or anything of that nature. Also are you sure your using the correct part for the SVT? The MTX-75 slave cylinder can also fit the getrag but the hole for the shaft is too big. They look identical to each other only difference the hole diameter. If you put one on a SVT it will leak fluid, I know cause...
I started out with nothing and I still have most of it left
Hatch Nation #15 (Ole' Yeller') & #150 (The SVT)
Moderator for
sleepyboy is offline
