Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IMPORTANT: ALL MK3 Focus Owners, I could use your input.
Old 11-14-2012, 11:39 PM   #62
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,333, Level 72
Points: 12,333, Level: 72 Points: 12,333, Level: 72 Points: 12,333, Level: 72
Level Up 71% Completed
Forum Activity 5%
Buy-Sell-Trade Rating: (3)
Originally Posted by Zillon View Post
Yeah, sounds like you might have a bit of clunk there, Suss.
Sorry amigo. Welcome to the club.
Then it likely wasn't quite right from day one, but I guess its harder to notice it as being explicitly wrong if the radio is just loud enough. Although normally unless the blower was going very hard or I wanted to listen to a particular track loudly most of the time I stuck to between 5-10 (usually around 7) on the volume front.
I would have to say I think it was doing it from around the second day, but I can't be precise since I didn't think I was having an issue until I heard more about it. Most of the other videos did sort of sound "normal" to me based on my car, but if that just means my car is abnormal with the rest and that it should be quieter. I don't recall what my rental car had back in November of 2011 but I could swear it was quieter even though it was a sedan. It also had the LED dome lamps where as mine are freaking incandescent bulbs.
Great, so no just because you feel you're not experiencing an issue just could mean you've tuned it out, but its still there. I thought something seemed strange when it thwacked harder over bumps than I would think necessary. The tires are also a bit noisy at times, but the suspension is the part that would bother me.
Doesn't seem to be temperature related, but your survey says it needs to be and you can't choose both. Idk, seems like that happens over any bump at any temperature, although some don't seem to do it the same way.
suss6052 is online now
