Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Aftermarket Heated Seat Pads for 2012
Old 11-14-2012, 10:19 PM   #8
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,317, Level 72
Points: 12,317, Level: 72 Points: 12,317, Level: 72 Points: 12,317, Level: 72
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
Forum Activity 9%
Buy-Sell-Trade Rating: (3)
Originally Posted by merkidemis View Post
Thanks for the heads up. I'll do some testing with weights to verify the sensor function before I have a passenger there. Still, how would adding a pad affect this any differently then if someone was wearing thick pants, like snow pants?
If the OEM heating element is embedded in the foam or laminated to it, then I could totally see how tampering could cause a problem.
The oem heating element is glued/ stuck on the seat foam underneath the cover and if you have to remove/ replace it it needs to be changed as a unit. Wearing thick pants only redistributes the weight slightly, not enough to make it not sense the passenger, but putting something electrical which may either interfere electronically, or physically to the sensor it might be an issue.
It might not be a bit deal, but the O.E. part is glued into place with the sensor embedded in the foam afaik. They say it had to be replaced as a unit if you were to disassemble it for testing (if it was determined that the seat base needed a replaced element. The driver side doesn't have the same stipulations as far as I recall.
suss6052 is online now
