Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IMPORTANT: ALL MK3 Focus Owners, I could use your input.
Old 11-14-2012, 10:59 PM   #58
Fan#: 104836
What I Drive: 2013 Tangerine Scream ST
FF Reputation: 1 earthling_david Good Standing Member
I just completed the survey. I also completed one that you linked to from another thread. I'm not sure if that was the same one or not, so make sure I'm not double counted!
Thank you for doing all this work to sort out the problem.
Edit: I see from a prior post that I was already counted, so I shouldn't have filled in the survey again. Sorry! I'm the one with the ST builton 8/14 that clunks, and doesn't have the reinforcing plate.
Also, I have put a piece of thick, heavy duty double sided tape under the rubber piece that supports the coolant reservoir, on the off chance that the noise I'm hearing is the reservoir clunking. I haven't driven the car since I did that. I'll report back with the results the next time I'm out.
earthling_david is offline
