Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cheap Upgrades
Thread: Cheap Upgrades
Old 11-14-2012, 02:06 PM   #20
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,000, Level 76
Points: 14,000, Level: 76 Points: 14,000, Level: 76 Points: 14,000, Level: 76
Level Up 88% Completed
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
Some states have lays that state that you cant dump your exhaust under the occupied section of the vehicle. Since the Focus is all an "occupied" space, if your state has a problem they may call you out on it.
Also not to mention you have air vents in the trunk on both sides, the driver side air vent would most likely allow exhaust fumes to enter the cabin even more so when at an idle.
at the vary least after cutting it out, route some flexible pipe out the back or have a shop bend a piece should be in the 20-30 range for a small bent section. Then use an exhaust clamp to tighten it down.
Magus2727 is offline
