Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can't figure this out to save my life. Literally.
Old 11-13-2012, 09:28 AM   #11
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 8,762, Level 63
Points: 8,762, Level: 63 Points: 8,762, Level: 63 Points: 8,762, Level: 63
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
After you put your new parts on did you disconnect your negative side battery cable to reset your ECU?
If you haven't , you could try that . Leave the cable disconnected for around 10 minutes, then put the cable back on and start the car as normal and let it warm up as usual until you see the rpm drop to normal operating temps . Then take it out for about a 20 minute drive so the ecu can relearn the new parameters with the new parts .
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
