Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Variable speed light grind
Old 11-12-2012, 12:16 PM   #5
Gybson
Fan#: 105932
What I Drive: 2007 Pitch Black SES
FF Reputation: 1 Gybson Good Standing Member
[QUOTE=Geezer;4451894]
Originally Posted by Gybson View Post
The front right is making a periodic grinding noise when coasting. Under braking or accelerating, this sound isn't audible. It speeds/slows with the speed of the car, not with RPMs. Sounds worse at slower speeds. If coasting at 60mph it's nearly inaudible. /QUOTE]
MY initial opinion is that your pads on dragging on the rotor. This is usually caused by dirty or improperly lubricated caliper slider pins and is often overlooked during a brake job. Clean them and lubricate them with a high temp grease and then give us a follow up on what happens.
That was my thought too... I buttered up the pins really well when I did the brakes (not my first rodeo :)) I may tear into it this weekend and take another look though. Way easier to lube the pins rather than press in a new bearing. *shudder*
Makes sense too since the sound goes away when braking.
Gybson is offline
