Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Creating USB drive playlists (easy instructions for MyFord and Sync systems)
Old 11-12-2012, 11:02 AM   #1
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 12 2012sel Great Standing Member
Post Creating USB drive playlists (easy instructions for MyFord and Sync systems)
If you already have a usb drive full of music, you can skip to "Creating the playlist".
I have the basic MyFord and Sync system, but this might work just as well on MFT. Also, these instructions and the program explained below are for Windows computers.
I recently ripped all my CDs to MP3s and wanted to use a USB drive with the "MyFord and Sync" system. I was having difficulty figuring out how to create playlists. I can sometimes find Microsoft Media Player confusing and I needed something simple. I ended up finding a free program called "Playlist Creator" to easily create playlists straight off the USB drive files.
I'm pretty sure there are dozens of ways to do this using other programs and invite others to share complete and detailed instructions on this thread. Also, please provide links to other threads that explain utilizing USB drives to their fullest potential with the "MyFord and Sync" system.
Here's a description of the folder structure created automatically when I ripped my CD's. I then copied the files directly to my USB drive. On the top level are Artist folders and inside those are the Album folders and inside those are the individual MP3 files. This structure is typically how ripping software will save MP3s. I used Windows 7 Media Player 12 to rip my CDs and selected to rip at 256bit MP3 format. I set the "rip on CD insertion ON" and just kept feeding my computer CDs until I was done.
Artist
-AlbumX
--Song.mp3
--Song.mp3
--etc.
-AlbumY
--Song.mp3
--Song.mp3
--etc.
Artist
-Album
--Song.mp3
--Song.mp3
--etc.
Etc...
Free Shareware that I used (be sure to deselect all of the extra software they want to install during installation)...
http://oddgravity.de/app-opc.php
Once you have Playlist Creator installed and running on your Windows PC, plug in your USB drive and drag songs from the USB drive to the Playlist creator window. Once you have your list complete, set the Save location to the top level of the USB drive. Enter a simple file name that sync will voice-recognize easily, select .M3u as the file type and click Create Playlist. Now go test your new playlist.
I haven't tried any other folder structure but if you open the playlist created, you can see that the file locations are "relative" so I assume just about any folder structure will work.
If you try this out and find more interesting ways to use the program, please post details. Also, if you know of different ways to create playlists on USB drives, please leave detailed instruction on how you do it.
Below are instruction I found while researching this from a Ford rep on using Windows Media Player to create a Playlist.
Originally Posted by FordIVTteam View Post
Below are instructions for creating playlists through Windows Media Player.
Make sure the music is listed on the flash drive.
Transfer the music from the flash drive to Windows Media player in the MEDIA LIBRARY tab.
Click on PLAYLISTS, and then CREATE NEW PLAYLIST.
Go back to the Media Library and Sort the music by the file name to show the file path starting with the Flash Drive Location (E.g…E:\MUSIC\MYMUSIC\...).
Select the songs that you would like to add to the playlist and drag and drop them, or right click them and send them to the correct playlist.
Once the playlist is complete, click on FILE and then SAVE PLAYLIST AS.
Click on MY COMPUTER, and then select the drive associated with the flash drive.
Change the Save As Type to Any Playlist.
Name the file and click on SAVE.
EDIT: Feedback from using the instructions...
Originally Posted by spudhead View Post
I tried this method and got it to work. At first it did not work. You cannot save the playlist as "Relative". In Playlist Creator, hit the settings tab. Another window will pop up, then hit "Playlist details". Look under "Saving Playlist Entries" there is another sentence that says "Do you want to save the playlist absolute or relative. The default is relative so use the drop down menu and pick "absolute" not "absolute without drive".
Once this setting is changed, the directions in the quote above (which are in the first post) work like a charm
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
