Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - I done goofed
Thread: I done goofed
Old 11-11-2012, 02:10 PM   #11
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,356, Level 100
Points: 31,356, Level: 100 Points: 31,356, Level: 100 Points: 31,356, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
I think some responders are only reading part of the thread to answer the "new cyl" question...
The bench bleed suggestion is prob. a guess that it got SO dry that that procedure might help.
I USUALLY vacuum bleed, but sometimes need to pump a bit as well, each method (pressure, vacuum & pump) has "tricks" involved to make it work better and if not done "right" might leave some air in the system.
SHOULD be a simple procedure, but often needs to be done twice or with the right "tricks" to get it done satisfactorily.
Luck!
sailor is offline
