Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Anybody done an E85 conversion?
Old 11-10-2012, 02:44 PM   #20
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 68,266, Level 100
Points: 68,266, Level: 100 Points: 68,266, Level: 100 Points: 68,266, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Did you see the part where I had the octane tested and it was never above 95.? NEVER , 3 times 3 diff stations over time
I left out the part about the sticky build up in the top of the injectors over time , the black build up on the valves etc
"Note how the pump octane number [(MON+RON)/2] flattens out to about 96." that is a quote from the last test on e85 I read
You like a lot of others seem to be missing how/why e85 does what it does and it IS NOT the octane its latent heat of vaporization which is simply a measure of how much energy per unit mass it takes to change the phase (e85) from a liquid to a gas, this change pulls heat energy out of the air dropping its temperature , meaning it takes the heat out of the air and lowers the chance of knock
Sure a higher octane would help but in most cases its barely much higher then 93 , cooler are means more timing and in most cases means more power , to the point the octane does drop because of crap fuel mixed with ,then BOOM
Another fun fact is e85 has no octane rating sense only gasoline contains iso-octane all octane test are set up for gasoline , makes you go hmmmmmm ?????
And I could go on and on
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is offline
