Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ignition switch won't pop out
Old 11-10-2012, 01:57 PM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
What I Drive: 2012 YB SE HB, 2011 Edge SEL
Points 15,662, Level 80
Points: 15,662, Level: 80 Points: 15,662, Level: 80 Points: 15,662, Level: 80
Level Up 63% Completed
Level up: 63% Level up: 63% Level up: 63%
Forum Activity 4%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (19)
Originally Posted by mikeeshaq View Post
If the keyhole is offset rather than centered
You need to change it immediately
Ford has a kit where you match the tumblers to your existing key
If you wait till it does not turn at all then it will cost much more!
This it NEEDS to be changed before it locks up then it becomes a few hundred bucks to fix. You can buy a ign cly from a local lock smith and he can key it for you. This should cost no more than $100 and then install is pretty easy from there.
This is what you have to do if it locks up
This is what you have to do if you replace it now, see post 2
As you can see you wanna replace it now!
ZETEC Crew #26 SR #20 YELLOW BLAZE OWNERS GROUP#4
Moderator Pilot, 12 SE HB ╠╬╝, 2011 Ford Edge SEL AWD
SkyPilot is offline
