Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Titanium Oil leak?
Old 11-09-2012, 08:17 AM   #6
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 7,381, Level 57
Points: 7,381, Level: 57 Points: 7,381, Level: 57 Points: 7,381, Level: 57
Level Up 16% Completed
FF Reputation: 19 FordService Great Standing Member
Originally Posted by john43913 View Post
I'm no mechanic but I do my own oil changes. I just did my second oil change and noted some oil leaking.
Is this something to be worried about or should I just wipe it off and check it at the next oil change?...
Hi john43913,
Make an appointment so your dealer can inspect ASAP. Additionally, I'd like to escalate your case to your region's customer service manager so they can get involved. Please send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll get the ball rolling!
Originally Posted by cbdallas View Post
Kinda surprising that your clutches aren't acting up. I believe this is what you see when you have a bad transmission input seal, which is starting to rear its ugly head on a lot of members' cars.
The fact is that it's leaking, and it's not going to stop, so you might as well take it in...
You have a warranty, use it. That could be a rear engine seal or transmission input seal. Either way, it's the fault of the manufacturer, and they should repair it. I'd work with FCS on this site and make sure you get a loaner car. I'd imagine your car will be in the shop for a couple of weeks depending on how quickly they can jump on it. With this sort of repair, they should keep the car after the repair, and drive it to be sure that it was done correctly. I'd write down the odo reading- as I always do- but don't be surprised to see 50 miles or so more than you had when you dropped it off. They should make sure that it has as least as much fuel in it as it had when you dropped it off...
Originally Posted by Zillon View Post
You're not the first to note seepage from the bellhousing.
Take 'er in to the dealer.
Thanks for all the great info, folks. I'm sure john43913 appreciates it!
Have a great weekend!
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
M - F 11:30 a.m. - 8 p.m. ET | Send a PM? Pls allow 2 business days for reply
FordService is online now
