Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Sound System?
Old 11-08-2012, 04:46 PM   #12
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
the stock headunit puts out about 10w per channel to the speakers and the sub amp is between 20 and 30w if i remember right. might be higher than that, but not by much.
if you're wanting a new sub then you'll need to get a new amp as well. the stock one isn't designed to do more than what it has. you can use the box, but wouldn't only recommend that with a lower power aftermarket setup and would be a good idea to put some dynamat on/in it.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
