Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mityvac MV8000 = Motorcraft 416-D002 ?
Old 11-08-2012, 12:26 AM   #1
bboyjamin
Fan#: 103696
What I Drive: 2007 2.0L
Points 103, Level 2
Points: 103, Level: 2 Points: 103, Level: 2 Points: 103, Level: 2
Level Up 6% Completed
FF Reputation: 1 bboyjamin Good Standing Member
Hi, if anyone here is knowledgable on Motorcraft/Mityvac, please read on.
After installing a clutch master cylinder on my 2007 Focus, 2.0 Duratec, Alldata recommends reverse bleeding the clutch hydraulic system using Motorcraft Vacuum Pump Kit 416-D002 (D95L-7559-A).
Their instructions say to connect to the clutch slave bleeder and input 100 ml of brake fluid.
I'd like to know if the Mityvac MV8000 will do the job.
Things are expensive in small BC towns. This tool will cost over $100. If it will do the job, I'm willing to go for it as I'm sure I'll use it tons down the road.
Please advise.
Thanks.
bboyjamin is offline
