Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Camshaft specs...FINALLY!!!
Old 11-07-2012, 03:12 AM   #2
amc49
Fan#: 96610
Points 6,921, Level 54
Points: 6,921, Level: 54 Points: 6,921, Level: 54 Points: 6,921, Level: 54
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
Forum Activity 100%
Unless I am crazy that is a nonsensical lobe separation number, the range is generally from 100 or so to around 115...................
You have also picked wrong motor in Crane catalog, that SOHC is the old Pinto-Mustang II engine for RWD. Totally different engine with no common parts. Note the cam followers pictured on right hand page, The SPI uses rocker arms and lifters, not followers and lash adjusters. I used to work on those engines, I assure you those parts do not fit the SPI........
amc49 is offline
