Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Optimal Braking Performance from Stock Brakes
Old 11-06-2012, 10:42 AM   #5
Fan#: 1427
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The stock drum/rotor setup can be improved upon to work almost as good as a four corner disc one does. Both Mintex (AF's) and Porterfield (R4S) make a matching performance pad and shoe combo for most Foci. Naturally, these should be used with fresh rotors and drums. The most popular (and usually affordable) drums and rotors tend to be Centrics although there are others. Always use a fresh fluid (I like Castrol LMA or Valvoline Synthetic for their low moisture absorbing and temperature properties). A set of stainless braided lines (or new stock replacement hoses) will improve and/or restore pedal feel. And remember, tires are what stop a car. All the braking power in the world doesn't mean squat if you don't have good tires.
Geezer is offline
