Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SYNC never gets it right on first try...
Old 11-06-2012, 10:18 AM   #2
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,514, Level 30
Points: 2,514, Level: 30 Points: 2,514, Level: 30 Points: 2,514, Level: 30
Level Up 43% Completed
FF Reputation: 3 FordIVTteam Good Standing Member
Originally Posted by dorough View Post
After starting my car each time, my SYNC system never operates correctly on the first try. "Betty" always asks and listens for my voice command, which I clearly speak. But after I speak, SYNC give what sounds like a half-beep and the screen defaults back to the PHONE REDIAL screen and does nothing. If I activate SYNC again and repeat the procedure, it does exactly what it's supposed to do. Any ideas why and what I can do to correct this?
Hi, dorough -
How soon after starting the vehicle are you giving a command? The SYNC system needs time to detect and connect to your phone.
I recommend checking your SYNC Owner account for an available software update:
https://secure.syncmyride.com/Own/Mo...ent/Login.aspx
If you're currently running the latest, I suggest an alternative pairing process. Certain phones are known to hold the best connection when they're Reverse Paired. Instead of the usual process of your phone finding SYNC, SYNC will find your phone. Before doing so, you'll want to perform a Master Reset on your system. This will restore settings to factory defaults, but should help with the issue you're experiencing. Instructions for both processes are below.
MyFord:
http://support.ford.com/sync-technol...ter-reset-sync
http://support.ford.com/sync-technol...air-phone-sync
MyFord Touch:
http://support.ford.com/sync-technol...c-myford-touch
Let me know if this helps or if you have any questions.
Jaclyn
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
t: @FordService @FordFocus @Ford
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
