Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2002 Ford Focus SVT
Old 11-05-2012, 11:06 AM   #26
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
Good news and bad news.
Good news: I replaced the timing belt and pulleys (Gates kit). I also replaced the water pump. I also found a broken tensioner pulley. (Autozone replacement). Did I also mention that the water pump pulley bolts came off by hand?
Bad news: After 3.5 weeks of the car being it buttoned together and it wouldn't start.
Due to my lack of time and still no manual to speak of, I took it to my trusted mechanic. He also checked out the leak for me.
He said that I put the timing belt on wrong....$200 labor. He said there's a mark...not sure what I did wrong, but I still saved a couple hundred doing the other work myself.
More bad news: While he had it up on the lift, he said it was my heater core that was leaking...not a hose as I'd hoped. $550 to replace. I looked around and everything I found mentioned it was a rare failure, but a PITA to replace, so I bit the bullet.
More bad news: I still have the codes that initially made me guess the timing belt.
P0420-Catalyst System Efficiency Bank1 - I'm guessing cat or O2 sensors.
P1381-VCT over-advanced (Bank1)-not sure what this is???
P1518-Intake Manifold Runner Control Malfunction (Stuck open) -not sure what this is???
I'm pretty sure at this point I require a manual to know what theses sensors are and how to test them.
2002 Ford Focus SVT 125k
1996 Nissan Pathfinder 250k
2001 Suzuki Marauder VZ800 9.5k
SD_Rider is offline
