Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MASSIVE dogbone poly insert mount
Old 11-05-2012, 10:29 AM   #10
wordyahurdd
coooookie monster
wordyahurdd's Avatar
Fan#: 41401
What I Drive: 13'ST, 04'SVT
Points 16,555, Level 82
Points: 16,555, Level: 82 Points: 16,555, Level: 82 Points: 16,555, Level: 82
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 4%
FF Reputation: 7 wordyahurdd Good Standing Member
Buy-Sell-Trade Rating: (17)
Originally Posted by sleepyboy View Post
I had to manhandle mine lower mount in. I used the ES bushings which are damn near identical to the Massive mounts. Took a lot of muscle to pull the motor and trans out of the way. Also I think I had to get it in the perfect position before it slipped right in. I didn't have to do this with the other Prothane bushings which don't have the big lip around them. I highly recommend the ES bushing inserts over the Prothane ones or the Massive mount since it uses the same bushings or very similar bushings I should say, same design anyways. I ripped right through a Prothane mount where as the ES mount lasted years before ripping apart from age. Yes Poly mounts DO wear out lol.
did you pull the trans towards the drivers side? like i said i had the trans pushed upwards but not towards the drivers side hmmmmm
2013 ST(3)
2004 SVT - POWERWORK'd
Buell XB9s
wordyahurdd is offline
