Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Snows - Is it ok not to do the minus-one thing?
Old 11-05-2012, 08:26 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,740, Level 66
Points: 9,740, Level: 66 Points: 9,740, Level: 66 Points: 9,740, Level: 66
Level Up 23% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (15)
You will be fine staying at the same size. Typically, skinnier width is preferred for winter, will cut through the snow better vs floating on top with wide wheels. People will down size to increase sidewall height, give you more padding to deal with poor road conditions, nice to do.
Do take into consideration if you go with just swapping tires that unmounting your tires will probably be $10 or so a corner and then you have to do that again in the spring and you do risk your bead getting messed up, chance of ruining a tire...so it may be cheaper in the long run but could end up just being wasted money in the long haul
rambleon84 is offline
