Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Starting new build, need advice.
Old 11-04-2012, 11:29 PM   #7
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
plastidip is a good option. It does have some texture to it, but how much depends on how well you spray it. that also gives you the option to remove is later if you want a different color or put back to stock. What I have always used for interior painting is Krylon Fusion. It is designed to work on plastic without major prep work (no primer, just clean and paint). This will work on any hard plastic. If you're wanting to paint over the softer material in the car like the armrests, then plastidip will work better for that. Same goes for the outside. Paint or dip will work and each has it's own benefits.
I did krylon on the interior and works great, however on parts that get touched often (around radio, near door handles) it has faded and needs to be redone (keep in mind I just use the paint without any clearcoat over it). the ext I did plastidip black on my spoiler and rear emblems. ran it through a brushed carwash a few hours after spraying and it peeled one corner a little off one of the emblem letters, but the rest was fine (didn't let it set long enough after spraying).
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
