Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 11-04-2012, 10:04 AM   #55
sterg
Fan#: 86158
What I Drive: 2012 Focuse SE Kona blue
FF Reputation: 1 sterg Good Standing Member
The TSB 11-12-13 is specifically for the "automatic" dual clutch transmission as this is the only one that allegedly had this issue commonly enough to require a technical service bulletin. Are you losing engine oil? If so from where? Is the engine consuming the oil (burning it), leaking it?
The tsb mentioned is referring to an internal transmission seal leaking which leads to an external transmission fluid leak, this fluid leak allows fluid to contaminate the clutch pack destroying it.
I think the engine is consuming it. Nothing coming out of the exhaust. I'm losing between 1/2 to 1 quart between changes. The service advisore says 1 quart every 1000 miles is considered within specs.
Steve
2012 Kona Blue SE 5 speed sedan
Sport and Winter package
Moonroof
sterg is offline
