Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 11-03-2012, 08:23 AM   #54
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,333, Level 72
Points: 12,333, Level: 72 Points: 12,333, Level: 72 Points: 12,333, Level: 72
Level Up 71% Completed
Forum Activity 5%
Buy-Sell-Trade Rating: (3)
Originally Posted by sterg View Post
Is this for the automatic transmission only? I have the 5 speed and I lose oil. I should have a look underneath. I'v never seen any oil in the driveway.
The TSB 11-12-13 is specifically for the "automatic" dual clutch transmission as this is the only one that allegedly had this issue commonly enough to require a technical service bulletin. Are you losing engine oil? If so from where? Is the engine consuming the oil (burning it), leaking it?
The tsb mentioned is referring to an internal transmission seal leaking which leads to an external transmission fluid leak, this fluid leak allows fluid to contaminate the clutch pack destroying it.
suss6052 is offline
