Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 11-02-2012, 11:31 PM   #50
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,223, Level 72
Level Up 44% Completed
Forum Activity 3%
Buy-Sell-Trade Rating: (3)
Originally Posted by mthurman View Post
They are not mentioning transmission fluid at all...only oil from the engine that is leaking out. If the rear main seal is broken is it likely to cause transmission fluid to compromise the clutches? Thanks
Engine oil from a rear main seal can destroy the clutch the same as the transmission fluid, but that would have been a less likely leak and one that wasn't covered by this TSB.
The more common leak would be the one from a transmission seal leaking onto the clutches and seeping out of the case between the engine and gearbox.
suss6052 is offline
