Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Remote Start and "Open Door Shut Off"
Old 11-02-2012, 02:18 PM   #90
Blizzard35
Fan#: 88463
What I Drive: 2012 Lincoln MKZ AWD Ingot Silver
FF Reputation: 2 Blizzard35 Good Standing Member
Originally Posted by ixNay View Post
Hello,
I hope I am not beating a dead horse here by bringing this topic back alive after several months, but i have an issue.
I have a 2012 Ford Focus Titanium Hatchback with Push Button Start with a Ford remote starter installed. I have been through this topic several times reading what people have tried and I have printed out suggestions with no success. Basically, I have the same issue as others regarding starting the car via remote then opening the door and the car shuts off.
I located the remote start module and push button up and behind the passenger side glove box. When I press the button and hold it for 10 seconds nothing happens, no horn chirping (While the car is running). I did notice that when I press the button and hold or if I just press and release the button that a red LED light flashes 3 times.
Am I currently missing something?
I do have an active "MyKey" which I have tried to reset to the default Non-Active, but it will not reset. The manual states that if I go to "Settings" then to my key and hold the down-arrow button it will reset. Mine scrolls to the mykey miles then back to the mykey active message without resetting. My remote start is the uni-directional I believe.
If you have any ideas suggestions I would appreciate it
Thanks
FWIW.....I have figured out with my Titanium with remote start that if I have started the car, with the remote starter, all I have to do for the car "NOT" to shut off is to open the car by using the unlock button on the keyless entry key fob. So long as I do that, the car will remain on even when I open the door. If I try to use the intelligent access opening of the car door (touch one of the door handles and then open the door) then the car will shut off.
Blizzard35 is offline
