Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - JRSC just installed....car will turn over but won't idle
Old 11-01-2012, 05:20 PM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 67,702, Level 100
Points: 67,702, Level: 100 Points: 67,702, Level: 100 Points: 67,702, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Originally Posted by mj22 View Post
Hey Tom
The car reads 0 fuel psi even when cranking.
However, like I said there is definetely some fuel there to get it started.
I also checked a datalog that I completed prior to installing the JRSC kit and it was reading fuel pressure. ie. the datalogging does work with Australian delivered focus.
If you have anymore thoughts that would be great.
Thanks!
You have the return fuel system , close off the return side and see what psi you have or go back to the stock tune and see if it will start altho it will run like crap but see if it runs , if it does its tune related
If you have a adj fuel psi regulator you can back off the fuel psi with the stock tune back in there or put the stock injectors back in just for testing
Whats your ECU code
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is online now
