Old 11-01-2012, 03:28 PM   #1454
Lipshurt
Fan#: 92314
What I Drive: 2012 blue focus SE
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 2 Lipshurt Good Standing Member
Do you guys think that the bolts are loosening? or do you think that 25 Ft/lbs is just too little torque? It seems that nearly everyone who has had the TSB has reported a certain amount of time when there was no sound. Mine took about 3 days, and i felt it loosen up when i when over a two inch pavement change while turning.
Does that mean that something shifts and then starts knocking, or that the bolts just loosened up. After a while it gets worse and worse, so something is loosening.
If its loosening, wouldn't some sort of lock washer, or locktite thread locker be better than simply adding torque?
Lipshurt is offline
