Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What octane fuel to use?
Old 10-30-2012, 08:19 AM   #9
Fan4Focus
Fan#: 104234
What I Drive: 2001 White ZX3
Points 146, Level 2
Points: 146, Level: 2 Points: 146, Level: 2 Points: 146, Level: 2
Level Up 92% Completed
FF Reputation: 1 Fan4Focus Good Standing Member
Octane
I know I'm going to start a firestorm of replies with this post but, here we go. I see you are in Wisconsin so I know you have Ethanol available. Try mixing a 15-20% blend of E-85 with your regular grade. If WI has blended pump options, that would be the way to go. You get a little higher octane with the Ethanol and gain a little performance in acceleration. Contrary to the nay sayers, it will not harm your vehicle. You most likely already have a 10% blend in WI. I recently retired a 1993 Ford with 232,000 miles on it that I had been running a 30% blend of E-85 for the last 100K miles of it's life. I had no negative effects at all; no seal problems, no fuel line problems and the engine was still spotless inside. Besides a small boost in acceleration, I also see about a 5% improvement in fuel mileage both city and highway. The blend should also be a little cheaper.
Fan4Focus
Fan4Focus is offline
