Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Common Ford Focus Transmission Problem, How to fix
Old 10-29-2012, 01:24 AM   #83
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
Points 909, Level 16
Points: 909, Level: 16 Points: 909, Level: 16 Points: 909, Level: 16
Level Up 9% Completed
Forum Activity 4%
FF Reputation: 1 finalfantasy Good Standing Member
Originally Posted by aokrongly View Post
It is VERY IMPORTANT that you just apply a thin bead of gasket compound. Don't use too much or the excess will get into your transmission and cause a problem.
i did this and used a 1mm bead. was that too thin? the dealership mech said that It should be squirting out the sides.
im leaking on the back (its dripping off the bolts) and i see pink fluid on a harness in the front so i guess its spraying out the front too??
finalfantasy is offline
