Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - starting problem
Old 10-28-2012, 05:22 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,184, Level 93
Points: 23,184, Level: 93 Points: 23,184, Level: 93 Points: 23,184, Level: 93
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I'm not sure what you mean by "dump test".
On our side of the pond we do 'load testing'. That is where we apply an electrical load to the battery and then test it's lowest voltage. This also removes any surface charge.
Most times a good battery will load test just over 12 volts, but I've never seen one test at 12.65v. That sounds more like at rest voltage to me.
With the battery in the car, key in the run position, turn the heater fan on high and put the meter on the battery,,, what does it read now?
If it's lower than 12v, I'd say the battery is done for ... or if it has a removable top maybe you can add some water and limp it along for a few more months.
but everything does seems to point at the battery being the biggest problem. Second in line would be the cables themselves.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
