Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - transmission fluid change
Old 10-28-2012, 01:28 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,473, Level 99
Points: 29,473, Level: 99 Points: 29,473, Level: 99 Points: 29,473, Level: 99
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Forum Activity 100%
The "Fill" plug is at the "full" level, so if you add until it comes back out the hole - then let it drain 'till it stops - it's full.
Actually a LOT easier than dribbling in a bit, checking with a dipstick & repeating until the level is right - then draining some out again when you add too much.....
A LOT of transmissions & rear axles work this way, it's a cheap & easy way to set a fluid level.
Luck!
sailor is online now
