Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuel pump problems
Old 10-28-2012, 10:07 AM   #11
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,444, Level 100
Points: 32,444, Level: 100 Points: 32,444, Level: 100 Points: 32,444, Level: 100
Forum Activity 52%
Activity: 52% Activity: 52% Activity: 52%
Originally Posted by Davidt2169 View Post
this is what i believe is my issue as well, it will start for a bit then die.
have you had it keep running for any amount of time? i had mine start but stutter while driving(accelerating and when getting on it) then would idle down and die at stops.
1turbofocus is right, datalogging would help you figure out if your problem was the same as the OP. You might be better off starting your own thread because even though symptoms are similar- the causes might be different. The first thing you should do is see if you can hear the fuel pump when you turn the key from OFF to ON. If you can, then you're better off diagnosing with another angle more towards checking the coil pack and it's power wiring.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
