Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - oil question , simple.
Old 10-27-2012, 11:22 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,045, Level 93
Points: 23,045, Level: 93 Points: 23,045, Level: 93 Points: 23,045, Level: 93
Level Up 70% Completed
Forum Activity 30%
Activity: 30% Activity: 30% Activity: 30%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
It really doesn't matter what benefits there are. It's free. Which is always a benefit.
But depending on what oil/s you've run in the past the syn may clean the engine out,, sludge and whatnot ,,, but the zetec doesn't sludge bad at all (if any) from what I've seen. So you should be just fine.
And if you're curious about why I say low is better than over (because I'm anxious to explain, just in that kind of mood)
It all has to do with the PCV system.
The air volume the pistons displace in the combustion chambers (~1998cc's) is about equal the the volume they displace in the oil pan. The pan is actually a bit bigger. This is done so pressure doesn't build in the bottom end, which would reduce TQ because the piston has to move through pressure, more resistance.
Too much oil can raise the pressure through the PCV and coat the intake with more oil than normal.
It's one of those things most don't know or think about. So it's just kinda neat to know.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
