Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - help needed
Thread: help needed
Old 10-27-2012, 10:26 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,033, Level 93
Points: 23,033, Level: 93 Points: 23,033, Level: 93 Points: 23,033, Level: 93
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Yes.
Fluid lean on/near the clutch peddle is almost always the Clutch Master Cylinder. Replace with Motorcraft part.
Lack of power could be a few things.
The 'steady acceleration' to me says that it may be a problem with the Throttle Position Sensor or the Mass Air Flow Sensor. Both should throw a code if there is a problem (check engine light). But sometimes the light won't illuminate. Best bet is to use a scan tool and check for codes through the OBDII port (bottom of dash near the hood release).
If any codes are found, write them down and post back with what they are.
Go from there.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
