Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Unhappy With Transmission
Old 10-27-2012, 01:36 PM   #5
tigertiger
Fan#: 85787
What I Drive: 2004 green ranger; 2012 Focus SEL
FF Reputation: 1 tigertiger Good Standing Member
Originally Posted by dan50 View Post
First, not "every" Focus makes noise when shifting. I've driven several and none had that problem. Second, you don't say how many miles your Focus has, but they do get better with age.
Noises and other transmission weirdness seem to have two main causes: out-of-date software (has your car received FSA 12b37?) or an internal oil leak that contaminates the clutch plates. The software issue is easily addressed by your dealer. The clutch issue may be a struggle if there isn't a visible fluid leak.
Try it again with the dealer. See if you can take a mechanic on a drive with your car and then one off the lot. Or see if a mechanic will take your car home overnight. Be as specific as possible about the behavior you're experiencing and when it occurs. Look over this board for some success stories dealing with oil-contaminated clutches, print and give to the technician. If this doesn't work, look for Crystal or one of the Fords reps that monitor this board: they can get extra attention from the dealer network.
I don't think the difficulty getting things fixed is because Ford is trying to avoid the issue. The real problem seems to be a dealer network unprepared to deal with a new technology.
This is all good advice and accurate, I think. My wife's had the transmission seals and clutch assembly replaced. It's like a new car now. It had the grinding noise, shuddering and rough shifting.
I especially agree with the last statement about the dealer network, though I know some may disagree with your assessment of Ford corporate.
When I first took the car in and mentioned the grinding noise and shuddering at low speeds when it had only around 1k miles, the service advisor did not even know the car had a clutch. First, it was, "It's an automatic, it doesn't have a clutch." Then it was, "That's normal for these cars." That last one was even after a tech drove with me, heard the grinding noise and acknowledged it was not supposed to do it, but then after contacting Ford, reverted to the "it's normal" line.
Very slowly, my dealer seems to have become aware of the technology and problems with the car and has been (mostly) good at dealing with them.
One thing I would advise anyone is DO NOT let anyone tell you the grinding noise and the shuddering are normal.
tigertiger is offline
