Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - transmission fluid change
Old 10-27-2012, 12:48 PM   #3
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,903, Level 100
Points: 31,903, Level: 100 Points: 31,903, Level: 100 Points: 31,903, Level: 100
Forum Activity 100%
X2
That "Parts Store" advice is 20-30 yrs. out of date.....
It's been about that long since all manual transmissions used gear oil...
SO, the "Right" lubricant will make the trans work easier/last longer than a "generic" fluid - the "wrong" thing prob. won't "break" it, but you won't be happy with the results!
For example, imagine how stiff the shifting would be if you used gear oil in a trans. that was originally filled with ATF on a cold winter's day!!!
The Ford synthetic fluid is quite pricey, but when using it the trans shifts "slick" and you won't have to worry about excessive wear since it's the best lube avail. for the purpose.
Luck!
sailor is offline
