Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2004 LX 2.0 SPI tries to start but won"t
Old 10-27-2012, 11:50 AM   #12
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,430, Level 29
Points: 2,430, Level: 29 Points: 2,430, Level: 29 Points: 2,430, Level: 29
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 7%
Buy-Sell-Trade Rating: (3)
If you've confirmed spark and fuel properly, then time to move on. Buy yourself a compression tester from the local auto parts store - $30.
If your compression shows low readings or readings are "lopsided" then timing is most likely the problem and the timing belt may have shed a few teeth and slipped. If you're not so lucky, one cylinder may read very low due to valve seat problems.
Crank position sensor is fine is you have spark.
IACV problems would result in an inability to idle consistently, not a no-start condition.
BC_ZX3 is offline
