Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuel pump problems
Old 10-27-2012, 12:03 PM   #6
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2013 Escape 1.6L Ecoboost GingerAle
Points 4,842, Level 44
Points: 4,842, Level: 44 Points: 4,842, Level: 44 Points: 4,842, Level: 44
Level Up 46% Completed
FF Reputation: 28 ah1f39 Great Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by starfuryt550 View Post
Find the relay, then find another in the bay that is the same one. Swap them. See if that helps or if the other system controlled by the same relay now doesn't work with the swap. You'll eliminate the relay as a problem. There should be several of the same ones under the hood.
I can get you some relays from the yard if need be...
Worked fine after the swap till parked. Is compatible, it is the Zetec harness.
Hatch Nation #115
Moderator For
ah1f39 is offline
