Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuel pump problems
Old 10-27-2012, 10:26 AM   #4
starfuryt550
Vinyl + LED guru
Fan#: 18440
What I Drive: Audi S4, Volvo S40
Points 26,085, Level 96
Points: 26,085, Level: 96 Points: 26,085, Level: 96 Points: 26,085, Level: 96
Level Up 74% Completed
FF Reputation: 22 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (59)
Find the relay, then find another in the bay that is the same one. Swap them. See if that helps or if the other system controlled by the same relay now doesn't work with the swap. You'll eliminate the relay as a problem. There should be several of the same ones under the hood.
I can get you some relays from the yard if need be...
Daily: Volvo S40 | Project: n/a at the moment
starfuryt550 is offline
