Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - buying an svt focus
Old 10-27-2012, 03:59 AM   #8
Fan#: 93397
What I Drive: 2007 Focus SE 4dr Dark Shadow Gray
Points 675, Level 13
Points: 675, Level: 13 Points: 675, Level: 13 Points: 675, Level: 13
Level Up 50% Completed
FF Reputation: 1 WSkobra Good Standing Member
Originally Posted by _Auricom_ View Post
I have not had anytime to do anything. Work is eccompasing my life right now, I mean I have no life, cant complain though, I want to install the TB though so let me know when your available man, I can stop by and get us sum drinks if you want. on me! lemme know.
Well I will not be able to do anything for couple weeks. Right now my car is in the shop. I am replacing the transmission that I just swapped into the car. From what the shop told me he said it sounds like the shifter rail that controls the shifter forks probably either is bent and is jammed up in the transmission or it broke in half. I say in half because when you open the hood you can manually move the one part to shift it so that tells me its broke in half. Transmission broke on me as I pulled into work. Which sucks cause I live 30+ miles away from work.
WSkobra is offline
