Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hesitation at speed
Old 10-26-2012, 02:11 PM   #5
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 6,931, Level 54
Points: 6,931, Level: 54 Points: 6,931, Level: 54 Points: 6,931, Level: 54
Level Up 91% Completed
FF Reputation: 19 FordService Great Standing Member
Originally Posted by dckotwicki View Post
I own a 2010 Focus SEL with 50K miles on it. I am noticing a slight / subtle hesitation while at speed. I can be doing 50MPH, 70MPH, cruise on or cruise off and I feel a hesitation from the engine. It is as if it is windy out and the car is buffetting slightly but is is not windy...
Hi dckotwicki,
I would advise that you make an appointment at your dealership so they can take a look. Ford certified techs are in the best position to diagnose and repair your Focus. If you have any questions, feel free to reach out to me via PM.
Originally Posted by Jgrove998 View Post
I believe you have a "in tank" fuel filter on that model.
Only thing I would suggest is getting some new spark plugs (I would recommend Autolite 104's properly gapped).
You could also check and be sure there is no corrosion on your battery terminals.
Originally Posted by sgtsmasher View Post
how about when your coming to a stop?
does it do anything then, or when your slowing down?
any unusual vibrating?
the only reason i ask is cause ive had brake problems before and thats what it feels like, is that the car accelerates hard and brakes fast and when at speed the rotors can heat up some wicked and slow the car down to where you can notice a difference. i cant hurt to check. ive had brake new calipers fail on me before, its very common but can happen!
50k miles over 2 years is average mileage. You shouldn't be having any problems with anything just yet- as far as spark plugs and coil boots go. I would consider pulling the coils and boots off each plug and seeing if there is any oil in any of the wells. You might have a bad valve cover gasket that is causing some problems.
Although earlier fuel filters were required to be changed every 20-30k miles, I do believe that Ford switched to a "lifetime" filter in your vehicle. Hopefully someone with an 2010 will chime in to verify.
All great info, folks. Thanks!
Have a great weekend,
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
M - F 11:30 a.m. - 8 p.m. ET | Send a PM? Pls allow 2 business days for reply
FordService is online now
