Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dry Sump worth it?
Old 10-26-2012, 12:31 AM   #6
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 13,861, Level 76
Points: 13,861, Level: 76 Points: 13,861, Level: 76 Points: 13,861, Level: 76
Level Up 53% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Sleepyboy, Who all makes aftermarket oil pump gears? I have been waiting since June for C-F-M to re source theirs. I was not aware of any other company that does. I do not plan on taking my car much over the 7,400 RPM because our motors dont really make any power up their any way. I just wanted them for that extra little insurance. I am guessing also due to the oil pump design and position, when the gears do brake as long as you have an oil pressure gauge and you shut down as fast as you can you should not have any harm done to the motor, right?
So the lateral-G is not so much a worry with out wet-sump stock oil pump design? this is still going to be a DD but would like to take it to open track days as much as I can.
going with the Billet gears then (or aftermarket higher performance gears) you basically slightly changing the harmonics of the pump due to material properties being different and having the gears slightly stronger you making it so the can handle higher stress before they brake. The coating you mentioned (Tom) in a previous thread would just shift the harmonic up a little right?
Magus2727 is online now
