Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New timing belt rubbing
Old 10-25-2012, 07:46 PM   #19
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 399, Level 7
Points: 399, Level: 7 Points: 399, Level: 7 Points: 399, Level: 7
Level Up 98% Completed
FF Reputation: 2 150mphzetec Good Standing Member
Originally Posted by dirtbrown View Post
my belt is doing this as we speak.....its the 2nd time im running into this problem. im starting to think its a bad cam bearing or something
cam bearing wont cause this. Setting the tensioner incorrectly will. The belt will find its own natural resting space on the cam gears, it may not always be centered. If the belt is so far off the edge it is rubbing, then this is not the correct way. At this point it is in your best interest to retime your engine and tension the tensioner correctly. If the idler pulley for the timing belt has not been replaced, this is a good time to do this as well
150mphzetec is offline
